Lean running 2jz?
barry
Quebec
86.5 2jz single garrett car was running great did some mods 4'' innercooler and a new heater motor put the blow off on intake manifold and now it runs rough and after semi normal warm up runs 15.5-16+ wide band reading any suggestions will help.. Thanks
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
Is this at idle you are getting these readings? If so your O2 sensor might be going out for the stock ecu. I used to get the same problem burning at 17/18 afs when mine went out
barry
Quebec
Turns out from movin the computer around it pulled one of the aem bypass cable pin wires out i have a aem fic and it was the number 1 injector so it ran lean..fixed and works fine ..
