I just got my new cooleeze megatmouth dp on and my new aem wideband and took my car for a little test ride. When I first start the car, the wideband shows a little lean for a minute (mid to high 15's). after running for about 15 seconds it goes down to the high 13's. So I took the car for a test ride and it was running good afr's while cruising so I decided to get on it a bit and check it out, I slow down and hammer it through second and third and my afr's stay down around 11-13 but as soon as I left off the gas and let it coast to slow down, afr's go of the gauge. . .lean. I realize that I am not giving the car any gas so it will lean out a bit, but I just wanted to check and see if it is normal for this to happen or if its something I need to fix.
Thanks
Thanks
