OneJoeZee said:$5 says you're boiling your PS fluid. Coming out the top of the cap.
OneJoeZee said:yep. Add a PS cooler. See if it helps. With no cooler, your PS ATF can get pretty hot... Same with your fan ATF. Good to have a cooler for the fan fluid as well.
