Leaking coolant
Mk3 SuPrA
33
Corona
Replaced the HG and started it up and found a leak around the water pump so i replaced the water pump, but its still leaking from that area. It looks like its leaking from behind the water pump. Anyone have any idea where it could be leaking from? thanks for any help
radiod
1,342
Abbotsford, BC
There is a coolant hose that runs underneath the power steering resevoir, you could check there. Also, check the bottom of your thermostat housing. I've seen that leaking on a number of cars where you can't necessarily see it at first glance, but take a feel and it's wet.
Mk3 SuPrA
33
Corona
the thermostat housing? the part of it that bolts up to the block? not rite by the thermostat rite? cause i would be able to tell if it was leaking from there
radiod
1,342
Abbotsford, BC
It bolts on to the head. The piece that the upper rad hose fits on to. Don't just look for it there, feel for it and see if it's wet.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
There is a metal hardpipie that runs under the exhaust manifold and bolts the the lower timing cover which can leak. It is hard to see, you may need a mirror to look up in there, but it is another possible leak point in that area.
SRZMK3
the most typical place for any leak is that rubber hose that is under the distributor that goes onto the bottom of your thermostat housing, because its not a hose people really pay attention too and is not replaced often, look there its kind of a pain to get too you may have to unbolt the distributor to get to it..
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
funny... i have the same problem ..i replaced that 90*hose the water neck gasket and i still cant find the damm leak...i did a pressure check and the cold start injector sensor was leaking coolant and so was my thermostat housing!!! doesnt the thermostat houseing have a gasket???
Mk3 SuPrA
33
Corona
I. changed the hose under the distributor but maybe the clamp didn't get a good grip cause it was kinda hard to get those hose clamps to tighten up with a screw driver in there so I'll check it again..... it has a seal where the thermostat sits and where the water neck bolts up to the block and that's it
