For the last two years, I've had coolant disappearing (I only drive this car in the summer). A compression check tests ok per the TSRM. Last year (May 09) the hose that goes from the bottom of the thermostat into the engine block started leaking then exploded (split) on me. Two months after replacing that hose, the rear coolant host that goes into the back of the upper block burst as well. This season, the same front hose that goes from the thermostat to the engine block is starting to leak again. I did a coolant flush last year with the garden hose, but past that I don't know what's wrong. After I drive the car for a while, I turn the engine off and the coolant is dripping out from that hose connector. After about an hour with the engine off, the coolant reservoir is drained dry. It seems like there is a blockage and the pressure is splitting those hoses. Also, throughout the spring, summer, early fall, the heat sometimes works and sometimes doesn't. It may not work on an evening short drive, but after a short stop, come right on for the return home.
Thanks everyone.
Thanks everyone.
