Having a little over 1GB of picz of my Supra Project ,I decided that I can post some here
1.The Beginning:
Looking for a MR2 Turbo, I found the Supra by doing turbo search on CraigzList. The car was just parked for a little over 4 years.Knowing that ,I still decided that it will be a Phun project car so I paid $300 and it was all mine:
2.BaseLine
As a step one I wanted to restore some critical mechanical/electric stuff before I even drive it.
Generally speaking the car was quite neglected ,even before the 4 years park time... There was a small fire in the engine compartment (Due to Failed Alternator) so the harness was a mess.
After I redid the harness ,I've replaced all vacuum and coolant hoses mostly with Toyota parts from my local dealer ,accordion hose ,timing belt ,all seals (rear main and some diff seals were left for later) ,belts ,etc etc.
Started the car ,found that it could not rev pass 2000rpm. Luckily I've spend the time to read the latest Engine Control Systems PDF set (sourced From Toyota University ,use WinRar ,pass: toyotaturbo) and I immediately knew what the problem was. 2 Hours later the TPS was rebuild and calibrated. Then I drove the car for one block just to find out that I had vacuum leak ,blown turbo seals ,etc.
Knowing that the bloody colour of the interior is something that I can live with but I can't drive a car with a 3-spoke Chrome rims ,and the turbo seals ... I started looking for low mileage parts car. I few weeks later I found a treasure ,7xK Miles 87T at a local IAA auction.
Needles to say the Partz car was Extremely well taken care of ,truly collectors MKIII (if such thing exists:icon_conf ) with one owner that kept every single record from the vehicle sticker ... $900 rust repairs Invoice from the dealership ... all the way to the $700 that he Paid for a rebuild turbo from Parts.com:nono: Unfortunately the car was damaged beyond repair and it was only good for Donor Car...
I took the exhaust system ,Turbo ,Brake Calipers ,Rims from the Donor so finally the car was almost ready to hit the road. The only problem was the suspension ,neither of the Supras had good shocks (that is the reason the black one was totaled btw). So I went with Eibach/Koni combo - the first real upgrade...
1.The Beginning:
2.BaseLine
