Could not update the old thread ,but anyways I'm doing 1.5JZ now. Old threads are here and here
BaseLine:
Track/AutoX prepped MK3.
Rear end:
- Custom heavily reinforced rear SubFrame ()
- All 3+3 A1 Racing ARMS ()
- ST Sway Bar + Adjustable EndLinks )
- Blue Poly UPC Bushings + Zerks ()
- 6x Nylon SubFrame Spacers ()
Front:
-Custom AL Subframe Spacers
-LCA Blue Poly UPC Bushings + Zerks()
-Custom Adjustable UPC (Caster ,Camber) ()
- ST Sway Bar + Adjustable EndLinks ()
- Red Poly Rack bushings
- JIC Magic Lower Reinforcement Bar ()
-25mm H&R spacers ()
Suspension:
-Tein RAs ()
-Tein EDC ()
- Current Alignment specs (based on many AutoX and Track temp analyses for various street tires) ()
Wheels & Tires:
- 17x8.5 ,17x9.5 SSR Professor SP1 Wheels ()
- 4x Dunlop Direzza Sport Z1 255/40ZR17
Brakes:
- JDK front BBK- 13.1"@35mm rotor, Superlite 4 pot Calipers ()
- MKIV rear BBK (Jake Reed mounting hardware) ()
- upgraded brake master cylinder (1 1/8")?
- master cylinder to ST bracket ()
DriveTrain:
- Custom Diff (JZA70/MA70 Hybrid 4.1 ,Clutch Type) ()
- SupraSport 1pc DriveShaft
-Spec Stage 2+ Clutch
- LighWeight FW
-SOGI Shifter + 2x poly shifter bushings
BaseLine:
Rear end:
Front:
Suspension:
-Tein RAs ()
-Tein EDC ()
Wheels & Tires:
Brakes:
DriveTrain:
- LighWeight FW
