Lapping Compound...which grit?
Evilsupra
Boca Raton
jdub
Feb 10, 2006
10,730
Valley of the Sun
Diamond paste is muuuchhh faster...IJ recommends start with a 40, finish with a 15 on a freshly machined block deck. Make sure the block is flushed clean really well when done...you don't want either finding it's way into the moving parts ;)
JimR
Canada
What's the clover leaf stuff made from? (Edit: I see three abrasives for 'Clover lapping compounds'. My guess is White Aluminum Oxide for the Medium grade, although I'd want to use Boron Carbide).
I've also heard a recommendation to use silicone in all the bolt holes, let it dry, and then pull the plugs out after you're done lapping. This will prevent the compound from getting into the holes.
