kwik 7m-ge/gte q's
U
under_r8d
Guest
-I have a chance to get a 7m-ge out of a wrecked (in the rear) 91 toyota cressida that has only 42k. What i was wantng to know, Are the 7m-ge's in the cressida's the same as the ones in our supras?
-Are the internals the same from the 7m-gte to the 7m-ge, Obvisiously other than compresssion.
*bore-stroke-cams/head specs ?
*i would guess that it would better to turbo a an N/A car than build off a already t/c'ed car..Since the cams will have a higher lift and lobe.
And yes i searched :D
figgie
Twin Cities, Minnesot-ah
the motor is the same.
the OIL PAN IS NOT. You would have to use the oil pan that you have on the cresida. Same goes for the head being N/A can not be used with turbo as the turbo manifold is different than the N/A mani.
U
under_r8d
Guest
Ok..i think you misunderstood me.this motor would be going in a 3rd gen supra.Not t/c'ing a cressida.So i would need a supra oil pan then, right?
Is there an aftermarket turbo mani that would be beter to upgrade other than the oem turbo mani?..or are you saying i cannot use the n/a head at all?
Thanks Fig:icon_bigg
Afunk
53
Yes, he is right, you CAN use the NA head, it is the exact same with the exception of the cams and some airflow changes from certain years. When using the 7MGE from a Cressida, you need to swap the oil pan AND the oil pump from a Supra or else the Cressida oil pan will hit the crossmember. The sumps on the oil pumps are different so you need to switch them too.
Alex
U
under_r8d
Guest
Ok..thats good to know..Does anyone know makes the foward facing mani's?
figgie
ok
I reread my statement and i don't know what i was thinking when I typed that.. I KNEW you were installing the 7m-ge into a supra??? :aigo:
Yes you are correct you NEED the SUPRA oil pan and oil pump.
