koyo rad question
toyotahachiroku
23
vancouver
my stock 1jz rad started leaking so i replaced it with a koyo one along with a new trd1.3 rad cap and system flushed and then filled with 50/50 toyota red coolant. bled it well and capped it off. fill the reservoir too. but, i seem to be running into a problem where the reservior tank is not big enough. i dont know if the koyo has increased capacity over the stock or not. but, when hot, the reservoir would overflow very easily if i drive agressively. and when its cold, it would suck coolant in till its completely empty. it always smells like coolant at the front of the car now and i am having to top it up quite regularly. is this normal with a koyo? if it is, is there a bigger oem direct fit coolant reservoir tank replacement? part number please if there is!
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
oem replacement should be the same size. if its losing coolant there might jsut be a leak hehe, check the lines esp to turbos you may not see any on the ground and that might be because its burning off.. (or is a very small leak)
also check the top of the water pump there is a pipe that connects to the water neck(goes to top of radiator) that is held in with two toyota gaskets (they are softer than the stuff you get at a local parts store)
if it is filling with coolant out of nowhere it might just be air in the system somewhere pushing it out... maybe ;p
