knock sensors
87ttsupra
Wee turbo!!!
Apr 9, 2008
76
pueblo west
okay im on a time crunch to get my car done. im missing a #$%^ing knock sensor. is there a way to run my 7mgte with only one knock sensor?? or will it screw with the computer? i need some options but i have no money to spend. could i use an NA knock densor?
87ttsupra
Wee turbo!!!
Apr 9, 2008
76
pueblo west
il be using a piggy back so im not worried about running rich just woried if it would set it into limp mode or whatever that is?
kneedragger85
363
Boulder, CO
I would not recommend pulling fuel to fight your ECU but rather just replace the sensor asap to clear the code 51.
shaeff
Kurt is FTMFW x2!!!!
10
Around
metaphysico;1602402 said:
You can run it without the knock sensor, most of the time people do before they rewire them. Its just gonna make you run rich.
And retard the timing. Fuel mileage will be bad, power output will be low.
Agreed, however clearing the code will require replacing the sensor, pulling the EFI fuse for 30 seconds, and hoping that your wiring is good.
And it's code 52, not code 51.
87M-GTE;1603237 said:
No difference between Turbo and NA KS
sam
Correct.
87ttsupra
Wee turbo!!!
Apr 9, 2008
76
pueblo west
well i wont know if i have a code unfortunatly my cluster is gone had to do all new gagues. so i need bolth knock sensores or my car will run like hell?
mkiii222
Troy, MI
You could splice one sensor to both ECU leads. But I would consider it a short term solution until a 2nd sensor is in place.
And I wouldn't say it runs like hell. More like crap.
