Knock Sensor Testing ?
pocketrocket07
Minnesota
Can I test my knock sensor some way with a multimeter? I have it narrowed down to the knock sensor but I want to test them. What should I be looking for I I can test them too? Thanks
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
reasoning on why you think its the knock sensors?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
funny you mention knock sensors, I just threw out a good set I could have shipped to you to swap out.
The sensor is basically a microphone, I suppose a multimeter could tell you if the sensor is completely dead, but I don't think it will tell you if the sensor is flaky.
The best way to tell is to hook up a set of headphones with an amplifier and listen to it. That's a little expensive though.
Ken
350
Houston, TX
the 2jz tsrm says to use an ohmmeter and put one lead to the terminal of the knock sensor and the other lead to the body of the sensor.
no continuity = pass
continuity = fail
