Knock Sensor Rewire quick question
D.J.T.
877
Arkansas, United States
I'm in the process of the rewire & i have this question but none of the KS threads have the answer.. Probably a stupid question.
Ok in the the write up it says to SPLICE the coax cable conductor into the ks wire 5-6 inches away from the ECU.. Wouldn't it be better if i just cut the KS wire, strip the KS wire, & solder the coax cable conductor & the KS wire? I don't see the point of the Coax cable if the original cables are still connected to the ECU just for the hell of it.
