knock sensor q?
apexi287
401
Knoxville, TN
im getting code 52 which is my knock sensor code..the wire from the engine harness that goes to the clip that attaches to the sensor is completely broken off with no space what so ever topinch the wires back together..obviously i need to get a new connector to plug into the sensor but my question is if i run/drive the car with this disconnected can it cause issues with the car..overheating,stalling?..anything..let me know..thanks
Dirgle
Conjurer of Boost
Pauma Valley, CA
It just pulls timing and richens the fuel mixture a little. You can drive it without hurting it but it's going to run like crap. Also when you go to fix that wire don't forget there are two wires in there. An inner core wire and an outer shielding. These two wires can't touch and the shielding should be completely around the inner core otherwise it picks up interference from the spark plug wires and thinks your engine has a knock. To correctly repair it follow the instructions shown here: http://www.supras.com/06/techcenter/display.php?QID=69
