Knock Knock..
N
NDBoost
Guest
whos there?
Got some vids of my car, yeah.. im pretty sure its rod knock.
Quicktime is required to play the files, if someone has the ability to convert these that would be awesome to do that for me. thx
http://7mpwr.com/knock/1.3g2
http://7mpwr.com/knock/2.3g2
someone confirm that this is rod knock just so i can make sure.
edit i just realized this should be in the vids section, if thats true mods can you move it for me :)
N
NDBoost
Guest
haha, interesting one guy says it doesnt sound like RK, but it cant be good. Its gotten progressively worse and i mainly notice it inside the cockpit w/ tranny in N and rev at 2500-3000rpm other then that its not really noticeable(yet).
Anyone else got any thoughts?
N
NDBoost
Guest
its an auto tranny IJ, i havent noticed any change in tone
If the thrust bearings in the Motor are shagged you'll hear/feel it in the Clutch.
Also sometimes the front bearing in the trans can die and make noise and this will show up with the clutch as well.
OneJoeZee
Retired Post Whore
aboard the Argama
yeah. my friends focus SVT. at idle it sounds like a low "tick tick tick" with the pedal out. pedal down it goes away. this is what we're talking about right? i should let him know... and tell him the dealership that sold it to him(not more than a month or 2 ago) has some explaining to do.
N
NDBoost
Guest
someone told me they listened to my videos today and said they think this could be piston slap and not rod knock. Is there anyway to test/tell the difference?
N
NDBoost
Guest
IJ. said:
Did you try pulling injector clips to see if it comes or goes?
not yet i havent had time, i would like to do it tonight if i have free time. But will you be able to tell the diff of RK and Slap by doing that?
And can i pull the spark plugs and not the injectors? plugs seem alot easier to unclip at the coilpack rather then undoing each injector..
