Kind of a strange steering issue...
Backlash2032
1,823
Nebraska
Well this is my first car with PPS, and I believe thats the cause of my issue.. basically my steering is fairly tight for a 25 year old car, but every once in awhile when I turn left it is super loose. And only when I turn left... Right is always tight, and sometimes left is as well.
Now I was thinking that it was the PPS solenoid starting to kick the bucket.. or maybe it's my alignment being off but idk. Right now to go in a straight line I have to turn the wheel approx. 20 degrees to the right. I don't know if that would cause something like this? Other than that, I don't know. To me, if something in the steering was worn, it would be constantly loose, turning both ways..
Sent from my HTC6435LVW using Tapatalk
I would start with aligning the rack in te right position and having an alignment done.
Alignment shops don't align the rack in the right position.
Backlash2032
1,823
Nebraska
How would you align the rack? All I'd do is straighten the steering wheel and get toe *close* then take it to an alignment shop
Should be same amount of turns from center to lock to lock. Tie rods should be pretty close to equally spaced and then aligned.
Backlash2032
1,823
Nebraska
Okay so there's no adjustment for that on the rack, SHOULD be in the tie rods (but I suppose it could be steering shaft set on the splines incorrectly)
Backlash2032
1,823
Nebraska
Will do, doing a brake job on my girlfriends car so it'll probably be next week.. the struggle of going to school and work...
Backlash2032
1,823
Nebraska
What was left of my steering rack bushing.. lol
Backlash2032
1,823
Nebraska
As a temp fix I chopped a piece of hose off of an old intercooler hose. That'll be my bushing until I can get some polys
Backlash2032
1,823
Nebraska
Thank ya poodles! Got an autox tomorrow and I really don't wanna miss it for something as stupid as this haha.
