Killswitch for Supra (fuel and momentary)
SUPRASTEVE
Supra Maniak
Jun 13, 2007
504
So Cal
I want to know if anyone has done this and I want to know what do I need to do create a momemtary switch replaceing the clutch momentary with a different switch. I also want to know how to put a kill switch for the fuel pump. Placement is up to me for securty reasons but thats common sense. So I just need to know how. Thanks Supra guys.
Times are tuff and gotta beef up security.
-Steve Z
Mk3runner
2,033
Nor Cal
have a switch or two under dash only you know about.. fuses. a loaded gun near your bed.. just a few thoughts
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I wired in a fuel kill switch when I upgraded my fuel pump wiring. I used two relays to maintain the stock high/low voltage switching. The way I wired it, the kill switch breaks ground to the first relay, preventing this relay from switching and providing power to the pump.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
KicknAsphlt;1209004 said:
Simplest way -- wire a switch inline with the fuel pump wire...and/or the starter...not too difficult.
In my opinion, it isn't the smartest to put the kill switch on a supply wire...thats why the relay kill works well.
Mk3runner
2,033
Nor Cal
clutch switch, wire it to a push switch. my moms cruise control switch is a kill for the clutch switch. looks completely stock.
