JZA70 Torsen Differential - Info and Pictures
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
This Torsen differential I personally pulled from my 1991 JZA70 Supra. I took pictures of it bolted in the MK3 subframe and what it looks like on the inside.
The Torsen pumpkin looks almost the same as a regular MK3 diff on the outside, but once opened up its pretty apparent.
Regular LSD style Diff (this is a MKIII supra lsd centre in mx83 housing)
Torsen LSD Diff
Here are a couple pictures of it mounted in the sub frame and sitting on the floor.
Hope this helps. If anyone else has or knows more about these diffs post it up here to help out others who are looking!
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
Not really sure on all the differences but to put this differential into a non-torsen MK3 you need the Torsen axle shafts too (they are longer then normal).
I have heard you can put the torsen center section into a USDM pumpkin so you can still use the USDM axles. Not 100% on this since I have never tried it myself.
