Hey guys,
taking a different route with my JZA70, which has been off the road for almost 12 months with a mysterious electrical issue while I looked for a new auto electrician and tuner. I now have a Mitsubishi Lancer Evo 5 which is my daily and since I rarely drive the Supra, I decided I would focus on building it for track use in local time attack and club sprint events.
This is how it looked when i drove it last...
In the past 12 months I have had quite a lot of time to ponder which path I want to take with this car. Since ownership my main focus has been on getting it to turn corners and stop as well as possible before worrying about power. As a result, I am currently still running the stock twin turbos. I was using an Autronic SM4 ECU with which it made 340rwhp at around 17psi with tonnes of mid-range.
I have now decide to do the wiring all over again and will be using a Haltech PS2000 ECU, Haltech HP6 ingitor and Haltech Racepak logger dash to tell me all of the vitals as well as record lap times and other useful data
I am going to be running the car on Michelin Porsche cup racing slicks and I have a room full of other parts that need to go on the car still but current braking and suspension mods stand at:
HSD HR coilovers
Whiteline adjustable sway bars front and rear
BIC performance adjustable sway bar end links
Enegery suspension polyurethane front lower control arm bushes
Arizona Performance Wilwood 4 pot 13 inch brakes front with Performance Friction pads
Sitting in storage waiting to go on the car once I get it back from the workshop:
Evo Brembo rear calipers and Sti rotors for rear brake upgrade
Beech performance rear traction, camber, toe arms
Beech performance front upper camber arms
Solid front and rear subframe bushes (still pondering about whether or not to fit these)
Before sending the car off to the tuner, I stipped out as much of the interior as possible. All thats in there is a dash with nothing behind/under it except the steering column, the front door cards and a driver's seat.
Dry ice was handy in stripping the sound deadening...
Good news is after sitting in my folks driveway for 11 months, the car was finally towed off 4 days ago to commence wiring, followed by tuning along with a few other bits and pieces.
When i get it back I will be fitting the remainder of braking and suspension components before a wheel alignment, bolting the slicks on and making a return to the track!
A custom full roll cage (probably bolt in to retain street use in-case I ever want to sell the car) hopefully in the near future too. Will update as I go along!
HSD HR coilovers
