I was just wondering is the jza70 the same body as the ma70 with a different motor?Will parts interchange jsut wondering?
garagefujimoto said:All engine mounts/crossmembers changed for the 1990+ models 7M and 1JZ
1JZ 2.5 R's have a Torsen LSD instead of Clutch LSD
The gear ratio is 4.10, as opposed to 7M 3.7, 3.9
The radiator has an extra temp sensor, larger intercooler
Most replacement parts are the same. It is the same car.
7M-GTE said:actually I believe it's 89+... correct me if I'm wrong though... and I think the diff is a 4.30 instead of the 4.10... I think the 4.10 is an aftermarket lsd from torsen... I'm not sure about the extra temp sensor or larger IC... I think the IC's were the same from pre89 to post89... but that temp sensor I'm not to sure of... I know some of the 89+ powersteering racks had pps(progressive powersteering)... Im' not sure if this came on pre89 cars...
garagefujimoto said:Well if you aren't so sure... read, and learn. Don't post false info that has been in like 800 posts that could easily be clarified with the search button. I have 3 JZA70's in my garage right now, so I can get pics if you'd like to clarify any details.
The mounts and crossmember were changed in late 1989 for all cars
As we are talking only about JZA70 which began 1990, this is a moot point.
4.3 diffs only came on N/A 7M-GE's
Torsen is a kind of differential, not a brand. It is stock, not aftermarket.
The rad and i/c are different on 1JZ, not 87-88/89+ 7M's
We are talking about 1JZ's here. That is the title of the post "JZA70"
Late 89+ cars all have PPS regardless of engine.
Thank You
cjsupra90 said:I know that the N/A cars do not have it or atleast not standard equipment, but I think that turbo cars did have it standard and implied in the post by garagefugimotor
garagefujimoto said:Whatever. The question was in regard to cars originally built with 1JZ-GTE.
I only tried to clarify that information, and one or more members learned from it.
PS Thanx for the mispelled and bolded parts of your post, they were special
Torsen is a brand name. Many automakers use it.Torsen is a kind of differential, not a brand
Nick M said:
GrimJack said:Ok, everyone bickering needs to take a step back, a deep breath, and apologize to their fellow members for getting all bent out of shape over little details and semantics.
Chill folks, it's the internet.
