JZA70.....cant get any CEL codes???
becauseican
Vancouver
www.bicperformance.com
Well I have a rhd jza70 in the shop now that has a few issues, anyways I cant get any type of CEL code to show up, even if I unplug the TPS or MAP sensor. Has any of you experienced this before?. The car is stock exept 3" dp, exhaust, intake and SAFC and a Blitz ECU and a BCC and speed cut controler (I think). Ay ideas?
Randy
tissimo
Stock is boring :(
Melbourne, FL
does the cel work?
is it solid when you check it? might be an ecu.. try a known good one..
why does it have a blitz ecu and a scc and bcc..
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
yea it wouldn't need a BCC and SCC if it has a reflashed ecu. does the CEL even come on for the 3 seconds before you start it???
