JZ timing belt, cam position?
zokustyle
79
Blaine, WA
I've searched and come up with nothing on a specific way to set the cams.
I know the crank has to be TDC at #1, but all I can find is "align the marks" for the cam gears.
thanks in advance, fellas.
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
Cams can only go one way. Make sure you're at tdc on 1st and your cams are at 12 o'clock.
Also, keeping tension on the intake side of the belt is a PITA, so put the belt on the crank and make sure its tight on the intake pulley...then wrap it around the rest.
70dreams
MR.I GET IT DONE
Jul 17, 2007
99
New York, New York, United States
i jus did it last week , i set everything to 0 deg. cams at 0 crank at 0 tension on the intake side ,mine was giving me so mych shit i jus removed the tensioner all together it went on 2 seconds later , fold the belt flat against the cam and then push it over and wallla its on hope this works
OneJArpus
2,798
^ Hope it works????
Rotate the crank clockwise a few times then put it at TDC again and check the marks on the cam gears & crank pulley
if its all set at 0 spec THEN ur good. If not take belt off do it again.
It would suck to do all that work get the motor ready to be turned on and it won't start cuz the timing is off.
