Just wondering.......
gixxer750
2jzget comingsoon!
Mississippi
There isn't a dyno in the entire state of Mississippi that I know of. So I'm wondering what kind of power I should be expecting when I get finished with my mods for this month....
By the end of the month, this will be my current setup. All parts are ordered and on the way or already sitting in my garage. A few of these are installed already such as the turbo and brake setup. Some of these have nothing to do with hp, but I'm just gonna list them all.
BIC divorced downpipe, Lex AFM, Walbro 255lph Fuel pump, RC 550 cc injectors, Wideband o2 kit, Fully Custom hardpipes going through snorkel hole 2.25", Ported out 3000 pipe, 57 Trim CT26, Straight pipe 3" exhaust, Custom 3" Metal Accordian hose, No EGR, no charcole can, Redline fluids throughout, 4.30 Gears in the rear, Ported stock exhaust manifold, Ported intake manifold, oil filter relocation kit, NA intake cam, Electric Fans, Fluidyne radiator, NGK spark plug wires, autolite racing 3923's, Braided stainless brake hoses, Ceramic pads, Slotted rotors, Dot 4 Synthetic Brake fluid, ACT clutch, Cometic head gasket, ARP head studs, Ross Forged Pistons, 6M Crank
I think thats just about it. All that, and I'm still rolling around in a maroon car with trashed interior and a silver hood. Oh well, I guess you guys know where my priorities are. We are going to see if I can better my 13.5 at the track now. Oh and all of this is on a fresh engine with about 7000 miles on it. Should this put me over 400 hp at around 18psi?
ma71supraturbo
Redding, CA
www.geocities.com
400hp at the crank? Sure. I'd guess 325-375rwhp when tuned. -- You've got a pretty sound setup although I think your next mod should be IC.
For reference 91TBreezin put down a little over 300 at the wheels with a similar setup through an automatic (and at only 14psi). The only tuning he had was some fiddling with base fuel pressure
LuvMySilverSupra
Bay Area Supras
Bay Area, CA
considering he says there is no dyno and he didn't list a wideband as a mod i will say about 275 untill u get it tuned some how. other than that listen to jeff-the-man
ma71supraturbo
Redding, CA
www.geocities.com
gixxer750 said:
BIC divorced downpipe, Lex AFM, Walbro 255lph Fuel pump, RC 550 cc injectors, Wideband o2 kit, Fully Custom hardpipes going through snorkel hole 2.25", Ported out 3000 pipe, 57 Trim CT26, Straight pipe 3" exhaust, Custom 3" Metal Accordian hose, Ported stock exhaust manifold, Ported intake manifold, NA intake cam
He listed it, but now it seems like he doesn't have it :1zhelp:
Halsupramk3
444
Mississippi
Yea i would like to know where we can take our cars too. I think the closest one may be in birmingham or lightning motorsports in baton rouge.
I got my o2 problem solved. My original ecu doesnt recognize the 02 sensor anymore. I traded in a local spare and the code went away which makes me much happier. When you get your car running i definately need to see it. When you are assembling the car let me know i would like to be there.
If you get a portable wide band i would like to see what it reads on my car too if possible.
Justin727
T-virus infected
There is one guys. its a portable dyno in a trailor. They come around during the blow outs on the coast and cruisin the coast. They are from mississippi but i forgot where. sometimes they come out to Gulfport Dragway and Hub city... just gotta catch them. there are a few in La and bama.
