just wondering what i should do...
  • Thread starter Slow Poopra 7MGTE
  • Start date
S
Slow Poopra 7MGTE
Guest
i have a hks vpc system but im missing a air intake temp sensor and wiring harness, should i just scrap this for what its worth and just go in a lexus AFM direction, im pretty sure im selling the garrett t70 i have and going with just a t4 style 60-1 or 62-1 of some sort so i'd only be shooting for the 400 rwhp range, what do you guys think?
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
Temp sensor is $69 and you can hard wire the vpc in easily. Keep the t70, cause once you've had boost.... your going to want more...
shaeff
Kurt is FTMFW x2!!!!
11
Around
if you're just going for 400rwhp (same goal as me :)) then the lex will do just fine. i'd go with the lex, and it's cheaper. well, the MAF-T is a good alternative, as well. if i did my setup over again, i'd go MAF-T.
-shaeff
