The timer works fine in the aspect of letting the engine idle for a pre-detemined amount of time. It's the alarm + e brake that have me wondering.
The alarm does not activate when I lock the doors from the inside or out when the timer is still active with the car in ON mode. Afterwards it has to be re-locked to function.
The e-brake button function does not seem to work correctly for me. It does not shut the car off when you release the hand brake. My brake light does not ever go out in with the key in ON to begin with though, is there something wrong with the stock wiring? Or is that normal activity?
If I buy an aftermarket alarm will it act like its supposed to or will I have problems with that too?
Thanks!
Thanks!
