ok guys i just got back from the dyno today i think i did pretty good minus the problem i need help with.
mods:
na-t
turbo electronics
hardpipes
maf-t
stock 440's
3" exhuast
spearco IC
psi on the dyno chart is as follows: 13psi, 13psi, 11.7psi, 10.6psi (turned off boost controller)
dyno was a dynapack, so from what the owner said it reads about 9% less than other dynos, but its far more accurate
problem:
altho the car ran great you can hear i am getting detenation at above 5500rpm which is def not good. the tuner was saying its not the worse hes heard but its def not good and was suggesting higher octane (i used 93 octane which is the highest i can get besides race fuel), or maybe my valve springs are going or maybe even not enough fuel. this is why i'm going to ask you guys for your opinion. Now i have my maf-t (basic) setup so that my a/f is roughly 11.8. my timing is set to factory (10 i beleive)
solution?
what should i do? how do i tackle this? i was thinking should i put more fuel into WOT using the maf-t? do i need bigger injectors? etc. i'm not too good when it comes to fully understanding detenation, but hopefully you guys can educate me :1zhelp:.
edit: btw i should also say i was detonating at stock psi also at the same rpm
mods:
na-t
turbo electronics
hardpipes
maf-t
stock 440's
3" exhuast
spearco IC
problem:
solution?
