I had issues prior to the head gasket replace, setting code 31, dying when let off throttle all that is fixed, new afm. This cleared up all of my smoking issues, fuel fouled plugs and drivability.
Today after lettin the engine get up to operating temp setting the timing 10*, and checking all for leaks i found that it still smokes a bit? Doesnt smoke on start up or when idling, or when giving throttle, it only smokes when letting off.
I have inspected my turbo a few times, has some shaft play, more than i would like, saving up to get it rebuilt or replaced. Anyways can a bad turbo be causing this smoke? Remember it only does it when coming off throttle, around 3k.
The head was rebuilt prior to my purchase, never been broken in yet, so i would like to rule anything on the head, and not to mention it does not do it on start up as seals would show.
