Just did the foglight re-wire.
DegreE
500
Memphis & Miami
I effin love it!
Its so easy, I read the threads about people having trouble with it and I can't understand whats to hard about it. Its easier than wiring a A/F guage.
Anyways, yeah... I felt like I had to make a thread to express how I feel about this situation.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
its cause some of the different years have different wiring/different colors so when people go to wire theirs and the guide is all different they get tripped up
A-to-the-J
Panda™ and Pre-89 Gracer™
Feb 19, 2006
1,080
Anaheim/West Covina, CA
there's this one.
http://www.supramania.com/forums/showthread.php?t=92&highlight=foglight+rewire
i know a couple other ones, but can't find them right now
EDIT:
the SOGI site (look under body electrical)
http://www.supras.com/06/techcenter/techtips.php
Also,
Jeff Lange;285636 said:
All you are doing is isolating the fog circuit from the headlight circuit.
For Pre-89:
1. Find the fog light relay, cut the white/green wire (pin 3) and ground the side going to the relay.
2. Find the fog light switch, cut the red/black wire (pin 4) and connect the side going to the switch to a switched +12VDC power source. See Note
For 89+:
1. Find the fog light relay, cut the red/black wire (Pin 1) and connect the side going to the relay to a switched +12VDC power source. See Note
2. Find the fog light switch, cut the red/green wire (Pin 4) and ground the side going to the switch.
Note: For example: splice it into the black/red wire (Pin 2) on the cruise control switch (pre-89) or cruise control main relay (89+), or splice it into the red/yellow wire (Pin 2) on the fog light relay, however this will result in the fog lights functioning even if the car is off.
ERA
1,934
any way the wind blows
One of the first things I had done to the Supra :)
Edit: As a matter of fact, here is the first picture taken of the Supra back in '06. With the fog light re-wire all in it's stock ride height glory:
(Kind of dark.)
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
well if he's going to post pics, so am I
Supra&
