So i posted a few threads about me not being able to control my boost so this past thursday i took off the intake and checked every vacuum hose and every boost refrence lines and even made sure that the boost controller was set up right (GReddy Profec B V.1), everything was "A" o.k. So i then made sure the boost controller was getting proper power and even regrounded it. So then i was told to try a simple test and to bypass the boost controller solenoid box all together which i did, and it still acted the same would overboost and hit fuel cut like crazy. So now im thinking its my wastegate, but before i go off and spend $200 on a new GReddy P765 actuator i want to know is there anything else i should look for before i spend this money. Also would i be able to change the wastegate without removing the turbo?
Mods that relate to the turbo:
GReddy TD06H-20G (Came with car)
GReddy Type S BOV (Came with the car)
GReddy PRofec B V.1 (Came with the car)
Defi Boost Gauge (My vacuum at idle while in Park is about -16mmHg id say.)
Sigh
Thanks
~JDMMA70
Sigh
Thanks
~JDMMA70
