Ok so first I replaced the wiring harness with another, not brand new but in much better condition than my last. I took the throttle off and set it using a digital multimeter so the code 41 I was getting has not come back yet.
So I am now trying to set the timing correctly. I checked the alignment marks, good there, so when I follow the directions to put the cps it seems no matter how I do it the mark on the crank is always too far left or too far right. Say the spot where the 15-10-5-0 is but place the 0 where the 15 is or vice versa.
Also when I hold the pedal steady at 1500-2000 rpms the rpms will just drop then return and repeat. :aigo: It's starting to get to me but just looking to see what some other causes are.
Only code I get is 43 which is fine because I have a manual start switch set-up.
:1zhelp:
:1zhelp:
