Well I just bought a junkyard engine. The had 140,000 miles on it. The timimng cover had a sticker on it saying the belt was changed at 135XXX miles. I took cover off and it looks great no wear at all or dry-rot. They only thing is that it says it was done in 2004. Should I replace it?
Next the engine is out of a automatic car. someone told me that there was something you had to take out to be able to put the poilt bearing in but it looks to me that I won't have to take anything out. Is there supposed to be?
Should I think about replacing the oil pump? or headgasket? I'm going to see if the head was torqued down to 70ft-lbs tonight when I get a torque wrench.
I'm looking to get the best MPG's I can. I have the exhaust and intake taken care of but I was thinking about Egr block off's. Im not sure if that will help my gas mileage or what. Someone told me they thought it was bad to block them off when using a USDM ecu. true?
What type of oil should I use? I know that you should use synthic with the GTE's but should I use it in my GE? What weight?
Thanks for all the help.
