Jumper Harness Questions.
Troyota
I Love What You Do For Me
Jul 28, 2005
243
Roswell NM
Hey guys...I'm doing my Body Harness Jumper today. I have a couple questions though.
I'm using the diagrams on www.1jz-gte.us.
On the connections between JZA Connector IG1 and MA Connector M1 (the one for most of the guages) he shows pin IG1-19 to M1-8 to be the CEL. His show IG1-19 to be Gray and Green...mine is Gray and Red...does this matter? I have two Gray and Green wires at IG1-22 and IG1-23 that connect to each other downstream, should these wires be the CEL instead?!?
The Pink wires for the Speed Sensor...should I maybe wait to connect these until I have a Speed Cut Defenser to wire in between the two?!?
All of the extra wires that aren't being used...just cut them all together?!?
Any help would be greatly appreciated.
Troy
Troyota
Jul 28, 2005
243
Roswell NM
Oh crap...I just realized that the pink wire for the Speed Cut Defenser actually goes into the ECU not the body harness. I guess I answered my own question on that one. :D
Ken
350
Houston, TX
All you have to do is make sure that pin #19 (grey/green) of the IG1 connector is jumped to pin # 8 of the M1 connector just like it shows on the diagram. Nothing else. That's how it is set up on my harness and the CEL works flawlessly.
