jic magic coilovers?????
white89turbo402
5
omaha
i was wondering if any on has any experierance with them and if they are worth it b/c i can get a set 4 1250 new and i want them mostly 4 street driving but i do go to the track every so often so any help would be greatly appriated
Wiisass
I don't have any experience with them on Supras, but from what I've heard and seen the valving is similar to most of the other Japanese/asian stuff. So it's really not that great. So a rough ride and adjustability that doesn't really do anything just like everything else. So if that's what you want, then saving a couple hundred and getting something cheaper may be a better choice.
Unless someone has any data or experience to prove me wrong. And if they do, I would like to see it. It would be nice to know which dampers are bad and which aren't as bad.
karmasupra
67
Macon, GA
I've got a set of SF1's on my 89 and yeah they 're really stiff. You get use to the ride over time if used for a daily driver but better suited for the track, so if you have rough streets where you live you may want to consider other options.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
had them, ran them, threw them away. I had a set that were made in the late 90s they were called "JIC MAGIC PROTOTYPE" They were damp/height adjust. They were stiff as hell not even close to daily driver friendly. The set I had were really old, Im not sure how they are now. Im guessing they are still really stiff and meant for track use.
