Jet's rebuild.
Jetfixr757
Sleeper
Cocoa, Florida
Well folks, i got the block and head today, the tranny i got back last week, so now i have my work cut out for me, i will post up pictures this afternoon.
William 89T
Ditto on pics! ;)
And to think they thought I was mad when I suggested a rebuild gallery!
It's really good being able to follow everyone's progress makes it feel not so isolated here in Australia.
Jetfixr757
Sleeper
Cocoa, Florida
Finally......
Jetfixr757
Sleeper
Cocoa, Florida
Here's more.
Jetfixr757
Sleeper
Cocoa, Florida
Jetfixr757 said:
Here's more.
And More it will only allow 5, do you have a site that hosts pictures?
this is still good though.
William 89T
Jetfixr757
Sleeper
Cocoa, Florida
Jetfixr757 said:
Thanks i just had the head on to run some oil through the oil pump without spray painting the ceiling of my garage.
William 89T
Well slow but sure, the engine is in, the driveshaft, tranny and exhaust are hooked up, just have hook ups to do, preoil, install the tranny tubes and radiator and hopfully crank.
William
cold weather sucks.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Looks good man.
Poor Ian, stuck on some island out in the middle of the ocean...It's just sad, When is the bridge going to be built? Lol..
Jetfixr757
Sleeper
Cocoa, Florida
Got the hook ups done, cranks develops oil pressure, no fuel on #1 piston. That's the one that got cooked when i had the messed with the ecu, wonder if my ecu is TU.
Jet
Jetfixr757
Sleeper
Cocoa, Florida
No i have not but all the other pistons, when viewed through the plug hole are wet except #1. Wierd. I think maybe the ISC might have something to do with it as it is open and not hooked to the intake. I will do more troubleshooting before making a swap.
William aka Jet 89T
dbsupra90
toonar
indiucky
william-
dont think the isc would effect it. is there enough slack to swap the #2 and #1 injector wiring? i can hardly imagine its wiring since you have a brand new harness. but its worth a look if you can do it.
when you wiggle the injector does it still have a little play? perhaps when the injector was put in the rail the o ring rolled over blocking flow.
i dont have any more ideas. good luck!
