i deleted cruise control because i never used it. i still have it incase i want to put it back in. the engine bay is much nicer without it, though.
i never really looked at how to make the JDM TB work with the cruise control because i always intended on deleting it. however, it *shouldn't* be too difficult to fab up some sort of method for it to work. (either make your own linkage, or use a longer cable for the cruise control and wrap it around some how)
all i did with mine is secure the stock N/A throttle cable to the existing JDM bracket via a bolt/nut/washwer combo, and let it do it's thing. it's working pretty well.
the best way to do it would be to get an early '90s toyota 4runner throttle cable, as it will give you more room than the N/A cable will. (it's a tight fit, but it works)
