so i recently found out i am getting rod knock. so i know i am going to have to change bearings, if not more in the process. but i have already been getting alota parts together for a higher hp setup. now my question to you all is..... should i drive my car for a lil longer the way it is? then when i upgrade my manifolds and stuff, fix the bearings, head gasket, ect? or should i spend money on a jdm or used motor with low miles, put a metal hg in it and be done? which is better? and by better i mean worth putting my money into? my engine has 145k on it. kinda high if i dont rebuild it. where as i can get a used one with 40k or less. if i am planning on high hp i figure i might be better off with a motor that has lower miles. just thought i would get some sugeestions from people. i have heard of guys getting good deals on motors. any sugeestions would help. thanks-
