jdm oil pressure sending unit
RiyadYar
384
NY
i have a jdm 7mgte and a jdm oil pressure sending unit as pictured below. my oil pressure never worked. i will buy a usdm oil pressure sending unit because i know the jdm will probably fry my cluster. the only other problem i have is that on the wire harness i dont see any plug to plug in the sensor to what can i do ? ( i would like to use the stock guage)
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
the connector for the sender kinda snaps on and it has a rubber boot to cover the whole thing. shouldn't be to hard to find the connector off another member or something. on a side note, i have a brand new USDM 7mgte oil pressure sender i'm selling in my for sale thread for a good price if you're interested =0)
-t3d
RiyadYar
384
NY
i know how the connector looks but if i do get it from another member where would i tap into on the harness being that the original connector isnt on
jdub
Feb 10, 2006
10,730
Valley of the Sun
It's there, unless someone cut it off. In that case, look for a yellow wire with a black stripe. BTW - the ECU also senses oil pressure.
RiyadYar
384
NY
ok great so worst comes to worst i can splice it at the ecu ill be on the look out for that wire once i get home
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Any idea what it uses it for/what it controls based on the reading?
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
It's said the JDM sending unit will not work right but when I had the JDM sender it read the same as when I swapped for the USDM one. :dunno:
