ok so i need some oppinion here guys. JDM motor plus new headgasket and ARP studs. is this a good option for replacing my stock motor w/ a spun berring? also are there any other item i should replace on the motor before i put it in?
I got a jdm engine and went hks 1.2 and arp head bolts, since the engine was already out the rear main seal. water pump, cam seals, timing belt kit, and all the stuff that u can replace that will later be a pain to get to......good luck
