JDM JZA70 Wheel Question
Charlie97L
230
Clarksburg, MD
Ok, so I got my spankin new steering wheel installed... i'm having a bit of trouble getting the horn hooked up... any tips? i searched, couldn't find anything. maybe i just missed it. i just need to know which wire is which on the steering column... there were yellow and green and brown, 4 of them.
thanks a bunch! here are some pictures for your enjoyment.
I hooked my horn up on my Momo steering wheel but it was so long ago I don't remember which wire was for the horn. But it was pretty difficult to do because the stock horn uses a metal ring. I had to use a small piece of hard plastic tubing and glue it inside of my hub. Then I ran the wire through the tube and to the back of the steering wheel, if you can picture that.
For some reason I want to say that it is the yellow wire, but I'm not sure and my car is an 86.5, so the wiring could be different. I would just try to connect each wire and pushing the horn button until you find the right wire. Or it may be in the TSRM...
Good luck,
-Nick
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
isn't it the strange creamy looking wire? i'm sure that's the universal one on all years... being later model i think you have 4 wires going to cruise control... and the cream coloured one is the horn... it's off to the side in the bottom of the plug iirc
lemme know if you can't find it and i'll get off my ass and find the one i tore apart
