i was on horsepowerfreaks.com and i found this:
all that for $1978
my car has a stock headgasket which i have no idea if it has been replaced or not, car has 100k on it theres some corrosion all around. i was wondering what are the differences with the jdm? anything? cuz an engine with new headgasket (metal!!!), head studs, timing belt, waterpump, and seals for $2000 isnt all that bad, and the jdm's usually have like 60k on them or less.
Toyota Supra 86-92 Engine Longblocks - Rabid Chimp MK3 7M-GTE
JDM 7mgte Engine
If you're looking into replacing your tired, leaky 7mgte, but don't trust an engine that came from some hulk that's been sitting in a yard for ten years, get your peace of mind right with a Rabid Chimp JDM 7M-GTE. Each engine comes with the fuel rail, turbo, turbo manifold, injectors, intake plenum, and have the following new items installed:
-Water pump
-Timing belt
-Front and rear main seals
-Oil pump drive shaft seal
-Cam seals
-Valve cover gaskets
-ARP head studs
-TMS 1.4mm metal head gasket
In addition to the installation of the previous items, each JDM 7mgte's crank and rod bearings are visually inspected. Every engine has been compression tested, and will come with a one year warranty.
all that for $1978
