I'm going to be doing a 2j swap this summer if all goes well:love: , and I was just wondering would it be worth it to swap all the USDM 2j parts to the JDM 2j,
Model: Japan Spec. / U.S. Spec
Horsepower: 280hp@5600 / 320 hp
Torque: 318ft/lb@3600 / 315 ft/lb
Injectors: 430 cc / 540 cc
Injector Impedance: High Impedance / Low Impedance
Inlet Cam Duration: 224 deg / 233 deg
Inlet Cam Lift: 7.8mm / 8.25mm
Airflow Measurement: MAP sensor / Mass-Airflow sensor
Turbine Size: 60mm/48mm / 52mm/44mm
Compressor Size: 62mm/39mm / 58mm/39mm
Turbine material: (ceramic / Steel
or just go single??:evil2:
