j-tube advantage?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Keep in mind that if your FPR goes out on you and you're driving on just the J-tube to build fuel pressure, you're in severe limp mode, as in, do NOT go into boost, and get to a shop as soon as possible.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Oh yes, we've seen a few of them go. It's really annoying, because when they go, the vacuum in the intake manifold sucks fuel from the fuel rail into the intake manifold through the vacuum line. It's not nicely sprayed in there like the CSI, either, it's like pouring fuel in from a gas can. Engines tend to run like total shit, if they run at all.
zurud
351
Evansville, IN
No. without the j-tube, and your fpr broke, you wouldn't build any pressure in the fuel system to run your car. Your injectors will dribble the gas instead of misting it.
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
I would think it near impossible for the spring part of the regulator to fail, so diaphragm failure is about the only thing to go wrong.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
LOL - actually, the vacuum hose to the FPR isn't *that* big. Plus, liquid fuel doesn't burn well. Last time I helped with one of these, the first two cylinders were basically not firing, car was running on the back 4 only. We were pretty sure the head gasket had popped and coolant was preventing the first two from firing... imagine our surprise when we pulled off the head and the gasket was fine!
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
I've seen only one fail and it was in the manner Grim said. In that case the leak was small and the engine exhibited no symptoms. The leak was found only because I make checking them a habit. I use a hand pump for that by pulling a vacuum and watching for leakdown. A loss of rest pressure would be another indication but that can be caused by several things.
I'm assuming in theory Toyota sized the tube's orifice to somewhat allow the feedback system to compensate for an FPR leak but as Dan's sig so succinctly points out...;)
suprahabsfan
Boost Addict
Sep 28, 2007
328
Sylvania, OH
You HAVE to drill out/bypass/eliminate the J-tube if running a walbro fuel pump, or upgraded fuel system. The small hole will cause too much backpressure and your car will run rich. So there is no real gain, but is a necessity when upgrading your fuel system. If worried about stock FPR, buy an aeromotive FPR
