It's TURBO time!
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
OK so im sure i have "Rod knock" or some bad noise comming from my top end, on my ge...
So im going to get a gte from our friend over seas...
Is there anything i should do to the engine(gte) before i swap it?
MDCmotorsports
Indy 500
www.MDCmotorsports.com
PLEASE PLEASE SEARCH. This has been covered a million times.
(http://www.supramania.com/forums/showthread.php?t=19541)
For one million + 1...
-ARP head bolts with your choice of metal head gakset
-ARP rod bolts
-Inspect oil pump or replace
-Remove oil pan and clean.
-Front, rear main seals and cam seals
-Plugs and wires
-Heli coil the exhaust manifold threads in the head
-Install new timing belt
-Install new timing belt tensioner
-Resurface fly wheel
-Replace ALL HOSES and don't forget the thermostat housing to head triangle gasket!
