It started!!!! TIMING IS WAY OFFFFFF
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Ok I GOT IT STARTED!!!! Everything is fine except it dies! Timing is off, I cant figure out how to set it right, I dont have a light....
whats wrong!?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
too bad its 11, or id go to an advance auto and use their rent-a-parts shit for it.
miekedmr
mkiii in hibernation
Jul 12, 2005
513
Upstate NY
do it by ear, revving the engine.
drive it a little, see if it pings, if it does, retard it a bit.
then just drive real lightly till you get a light and do timing properly.
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
It has instructions.
Hook a lead to the 1st cylinder spark plug, electricity and ground. shine at crank. have an assistant work the distro. when its at 10* tighten and yo win
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
10? I set my crank to 0, put my distro to tdc and thrw it in... do I need to set my crank to 10 then put the distro in at 0?
Clip
Oct 16, 2005
2,738
9
Virginia
damn, then just buy one from autozone and use it lightly. after youre done return it.
clifftrail
128
Abq
Connect the positive and negative wires and clip the sensor wire around number 1 wire. Jumper the diagnosic connector, I think it's E1 and T1, then point it at the crank pulley and pull the trigger. The light will light with the firing of the cylinder. Loosen the bolt (12mm) on the CPS and turn it CW or CCW until you get it set. Then tighten and your done. This is all in the Tech manual that you can access somewhere on here, GL.
