Background: 1989 7m-gte, automatic, BPU (turbo back exhaust, intake, bosch bpv, AEM Truboost set to 11.5 psi)
I can't seem to find this boost/vacuum leak. I can hear something at idle, and its on the driver side around the throttle body, but might be back behind the engine on the intake side.. its hard to tell.
Ive sprayed soapy water on all the IC pipes, up to the TB. I pressurized the system to 20 psi from the turbo inlet to the end of the 3000 pipe. No leaks whatsoever. I don't believe its the TB gasket either.
I sprayed starter fluid in damn near every place I could think of while the engine was idling, and there was no change in rpms.
I pressurized the whole engine up to around 12 psi, and couldn't find much else than the egr vacuum modulator and the tps bleeding air. It was somewhat hard to listen, though, since air was just flowing through the engine.
I just had a Coolant/Heater line break and spray coolant, but that was only under boost. I replaced it, (it was the one running from the valve by the charcoal canister to the top of the cylinder head) and no longer have a coolant leak.
Under WOT, I usually hit 11.5 psi through all gears. Now, I only hit 8.5 psi in first, spikes to 10 in second but quickly back to 8.5, and spikes up to 12.4 in 3 (without O/D on) and once again, quickly drops back down to 8.5. I have the truboost set so it will light up red as an alarm at 12, but it doesn't alarm me when it spikes up for some reason.
My idle is between -12 and -17, usually closer to -12. (now averages about -15 with the new injector insulators/O-rings and 3000pipe couple/t-bolt clamps)
My Tru-boost "A" setting is hitting 7.5-8 psi, "B" is 8.5 psi, and "OFF" is 7.5 psi.
I just installed a wideband, so if those numbers will help, I can get them. I know its between 14.7-15.3 at idle and like 10.4 under WOT.
I just bought a new boost solenoid as I thought the old one was malfunctioning, but that wasn't the problem.
I have a 2.75" coupler with t-bolt clamps, injector o-ring kit, and TB/ISC gaskets. Just installed them, they didn't help much other than a slight vacuum at idle increase.
I have a full intercooler kit ready to be put on, but I would like to wait until I find this leak before installing as I know this will mess with the boost settings, and I would like to know 100% that the leak is fixed.
I've searched the forums, google, TSRM, everywhere I can think. Just cannot find this leak for the life of me..
All help is appreciated!
