hey guys,
My car recently developed a surging idle > It would idle high at startup and after a few seconds will start to surge up and down annoyingly.
So far i've checked the codes and TPS adjustments and still nothing.
No codes at all as well.
Removed the ISC valve and cleaned it up pretty darn good. and put it back on with the the same idle surging.
QUESTION:
What I noticed with the ISC is that the small motor or axle protruding from the motor does not move when I try to turn it. It appears locked. Should this be turning freely? I assume it should. I tried turning with a pliers and it would not budge.It felt like it was jammed.
Any insight and help would be great. If someone can check an ISC lying around and tell me if that little rod should be able to turn by hand , that would be awesome.
Thanks in advance,
Moe.
QUESTION:
Thanks in advance,
Moe.
