ISC Elimination?
dbsupra90
toonar
indiucky
you can elim the water lines. its mostly to keep it from freezing when you live/drive in a very cold climate.
the water lines also feed over to the tps. it just makes a big loop out of the block, isc/tps, back into block. all we do is just make a loop on the block from where it comes out to where it goes back in.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
why do people eliminate the coolant lines to it? curious. im not gonna do it regardless though i live in a cold climate =D
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
dont know if you care... but its easy to free up a good amount of space by getting rid of the heater valve... i did it because im getting rid of all of the vacuum lines and stuff i just dont want or need.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
To keep the intake cooler, which could equal more power.
Plus its one less hose you have to worry about leaking and makes things simpler.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Because they ultimately either get rid of the electronic, or do away with it as it's plumbed in tandum with the TB as mentioned above. The purpose there is if an aftermarket TB will be used, or they no longer want hot coolant heating up the intake air.
Oct 11, 2005
3,821
26
Thousand Oaks, CA
Its for high humidity conditions, not cold temperatures. At the ISC, there is a sudden pressure change (ambient to vac) and the temperature of the air will drop (basic physics) causing the water vapor in the air to freeze out and plug the valve.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Not with a stock set-up (i.e. AFM and ECU)...with speed density (stand alone or MAFT Pro), yes.
89Turbo
804
Portland
what kinda temperatures are we talkin, lowest it ever gets here is 25deg farenheit and its covered parking during winter.
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
Well. I'd just leave it stock. I'm better off doing this as i only drive my car in the summertime, and garage it in the winter. :)
