Looks like toyota is getting back to there performance stages again its no 2j but a v6 3.5 making 305hp is pretty damn impressive wonder how soons its gona be before we see this in a MKIII.....
Discuss.
Discuss.
supra90turbo said:Drive by wire isn't a restriction the moment you put the engine in another vehicle. Because then, you can do whatever you want!
Justin727 said:good enough for practicality. we tried it in shop. cable reacted just a little faster the fly by wire. or drive by wire as you call it figgie.
Although you are right some tundra drivers are looking for power low end and sometimes the dbw sux. Sometimes it'll roast em and most of the time its like a honda leavin the line
Motec are a bit fussy about validating the DBW hardware before they'll ok it for use...figgie said:DBW is not a restriction
as a matter of fact it is a two fold thing as it can be used as traction control and normal throttle
Of course it would take a motec to control DBW throttle but if it is good enough for F1 and most BMW, Ferraris and renaults then it is good enough for Chev, ford and Teeyota.![]()
IJ. said:Motec are a bit fussy about validating the DBW hardware before they'll ok it for use...
