Just some background info:
Swapping a 2jzge into a mk3 supra using 7MGTE electronics. So far I've swapped over the necessary sensors (knock, coolant, etc.).
Moving onto the ignition setup, I have the IS300 coil packs and vvti igniter. But from what I've seen, if I use the vvti igniter, I'd have to use some sort of aftermarket engine management (AEM v1, standalone, etc.). I was wondering if I could use the coils with the 7m ignitor?
I'm sure this has been covered somewhere already but any help would be great thanks!
