is this true
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i would think it would but might need modification
and they need to update that site
"For an aftermarket flywheel:
Order a 7M fly but have the 2J bolt pattern drilled into it."
you can just buy a lightened flywheel for a 1J now
tissimo
Stock is boring :(
Melbourne, FL
yea a 2jz could be made to work, but there are 1jz intercooler kits out now.. I think driftmotion has one.. MTR has one.. 935 might have one as well.. check into it..
935motorsports
San Diego, CA
sort of. You can use most of the parts from a 2J kit, especially the TB side. It also would require you to use a stock fender pipe from a 7mgte.
However, unless its nearly free, it's not worth the extra trouble when better fitting kits are available.
Even Blitz has a 1JZ intercooler kit.
